running duals off lpp Lts
Old Nov 4, 2009 | 04:11 PM
lglowe's Avatar
Default running duals off lpp Lts
Ok guys I currently have lpp long tubes with off road y and I'm looking to change to duals with an X pipe . I just need to know the best place to runs the drivers side pipe, what size pipe to use after the headers, and any other tips you wanny give me. Prolly either gonna run dual 18" magna flow or dual hookers
Old Nov 4, 2009 | 04:16 PM
lglowe's Avatar
Basically I'm just looking for that bad *** Ls1 camaro sound. Thanx
Old Nov 5, 2009 | 01:44 PM
AJK381's Avatar
i know ive seen someone on here that had one, and i plan do do it in a few weeks when i swap the 5.7 it was on the pass side with a close x-pipe the pipes basically followed eachother the whole way.
Old Nov 5, 2009 | 01:53 PM
Michael Halo's Avatar
x2 on this thread i wanna know to...
Old Nov 5, 2009 | 04:58 PM
PathfinderJr's Avatar
It's kinda hard to see from my pics, but I basically had the 'y' portion cut off and had the shop weld in my x-pipe right where the two collector pipes come together. The pipes just went side by side there on out.
You can click the pictures for bigger versions, too.
Old Nov 5, 2009 | 05:03 PM
And I personally went with 2.25" pipes for my duals because I wanted to keep a semblance of torque in the lower rpms. The slightly smaller pipes, which still add together to be a hair larger cross-sectional area than a single 3" pipe, help keep the exhaust gas velocity up in the lower part of the rpm range.
Some folks say go with 2.5" duals even on a 5.3. If you got a stall in that tranny along with your 4.10 gears, you can likely flash right through any loss of low-end torque, but it's your call.
Old Nov 5, 2009 | 05:18 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Buy this, your truck is ecsb too. https://www.performancetrucks.net/fo...ght=thunder550
Old Nov 5, 2009 | 07:12 PM
zachm89's Avatar
ive got duals running side by side down the passenger side of the truck on my sss, not really any other way to do it...if i were you id have a shop cut the pipes where they join together and weld up a 3" x-pipe then step it down to 2.5" after the x so you dont lose alot of low end, dual 3'' all the way back is way too big IMO unless youre running a big cam or a s/c
Old Nov 5, 2009 | 07:38 PM
lglowe's Avatar
cool peeps.. keeps the info coming... still dont know if a wanna get the maggie or the hooker though... i really like the sound of a ls1 car if yall know what im talking about..
Old Nov 5, 2009 | 08:25 PM
Bluchevypick's Avatar
I have an X on my true duals as well but I'm running 18 inch bullet mufflers. I went with 2.5" all the way though. Mine is also dumped but it sounds very good IMO.
