rpm output.
Old Dec 21, 2010 | 08:04 PM
1Bear's Avatar
Once you knew what signal your existing tach is needing, and once you know the signal type from the new ECM, it could be as simple as purchasing a tach signal adapter from a manufacturer such as MSD, Autometer or others.
Old Dec 21, 2010 | 08:12 PM
youngbuck's Avatar
So how do i findout what signal it needs?
Old Dec 21, 2010 | 08:13 PM
youngbuck's Avatar
And its an 04 tahoe ecu
Old Dec 22, 2010 | 11:55 PM
brandon6.0's Avatar
so are you saying that u spliced the white tach wire and ran it to your 93 gauge panel? or did u run it to a 99-newer gauge cluster? If it is hooked up to your 93 gauge cluster, it might be wrong signal pulse or something.
I just installed a 5" tach. And u do have to run the tach on a 4 cyl. pulse for it to work right.
BROKE-aSS-BLAZER
Oct 13, 2017 03:50 PM
00loudchevy
Dec 3, 2015 05:54 PM
Gadgetized
Oct 22, 2015 09:06 AM
Velocity1
Oct 2, 2015 08:01 AM
Chevy305
Sep 28, 2015 09:21 PM
