rough idle/ dies at stop lights
Old Nov 27, 2008 | 01:39 PM
jaegmc99's Avatar
Default rough idle/ dies at stop lights
My truck surges and will die at stop lights or when going from reverse to drive. It's been doing it for 3-4 months. I had to put in a fuel pump cause mine died, so it's not that. Thought it was the IAC so I replaced that. ran good and idled great for a day. Then started to surge at stop lights and die at idle. Now what? Change plug wires? coils? It has new plugs...uh help me!!!
Old Nov 27, 2008 | 01:41 PM
00ChevyScott's Avatar
Wearin' da big hat
did you do the tune? post it up if you can, maybe the desired airflow is messed up?
Old Nov 27, 2008 | 01:44 PM
dlt76028's Avatar
mine does this too quite often. i just cant seem to get the tune right?
Old Nov 27, 2008 | 01:49 PM
Wearin' da big hat
Mine does it too, but thats because my desired airflow isn't set right for the converter yet
Old Nov 27, 2008 | 01:52 PM
dlt76028's Avatar
whats yours set at? i want to compare it to mine.
Old Nov 27, 2008 | 01:59 PM
Wearin' da big hat
pm sent.
Idk if i got a pic of the right table tho
Old Nov 27, 2008 | 02:07 PM
EVILGMC's Avatar
check your TB for carbon buildup....even just a little will cause problems.
you can get a chemical cocktail from your dealer for doing a "de-carb"
dlt76028's Avatar
yours is higher then mine in some places and mine is higher then yours in some places... i was comparing my tune to other modified tunes with cams and stalls and their desired airflow is little higher then mine but theres a huge difference in the iac effective areas (iac steps) so im going to look into changing that...
Old Nov 27, 2008 | 02:09 PM
silveradol33's Avatar
Have you checked the IAC? That seems to be a common problem, take it out clean it and try that. If that does not work, try a new one.
Old Nov 27, 2008 | 02:10 PM
jaegmc99's Avatar
I will take out the TB and full clean it out. I do have a 3800 converter. Maybe my tune is off. I'll clean it though and log it, then post here.
