rough driving in heavy rain??
Old Oct 28, 2006 | 02:55 AM
blake2kz71's Avatar
Default rough driving in heavy rain??
I was driving down the interstate today in very heavy rain goin about 75-80. All of a sudden the truck feels like it just all of a sudden runs out of gas. It starts bucking real hard like the fuel pump is going bad. This is very strange the trucks never done this before. I have a keystone functional ram-air hood and the aem intake, i thought some water or moisture may have gotten on the maf possibly, but i have no idea.
Old Oct 28, 2006 | 08:30 AM
TurboGibbs's Avatar
Sounds very likely. The MAF is basically a heated element that measures air flow by a change in heat on the element (the way I understand it anyhow). Water introduced could greatly effect the rate of heat exchange and would richen up the mixture severly. Someone correct me if i'm wrong.
Old Oct 28, 2006 | 02:41 PM
kbracing96's Avatar
The MAF sensor goes to pretty much 0 when water hits it it. I have seen this in logs when I was spraying, meth through it, but is was disable (SD), but was still plugged in. Most likely you ingested some water. Did it thorw a P0101 or P0103 code?
Old Oct 28, 2006 | 03:07 PM
Bowtie70SS's Avatar
Same thing happens with my Suncoast hood. Turns out there were supposed to be drain holes in the air ducting that were missing. I drilled 3 holes and that helped out a lot, but I carry a shop fender cover around so I can stuff it in the hole in the underside of the hood. I also think the water getting in eventually caused my throttle body to go bad when it got moisture in it. I was considering making a plexiglass block off for it to install when it rains.
Dave
Old Oct 29, 2006 | 01:19 AM
blake2kz71's Avatar
well the only thing that makes me think it may not be that is because it has never done it before and iv had the hood for a while. The hood holds water until you open it and then it all comes out through the rails in it. I cant decide if it was just a coincidence it was raining or it thats what it was. I pulled over at a gas station and the top of the filter wasnt wet at all but the bottom was so duno. It definately wouldnt surprise me if the fuel pump, an injector, or a coil pack was going out with over 100k miles on the truck.
RedDeadG8
26
Dec 1, 2015 11:32 AM
black03rcsb
Sep 1, 2015 10:17 AM
BennyB
Aug 1, 2015 08:48 AM
GreyChevy
Jul 7, 2015 08:57 PM
