rod bolts
Old Aug 6, 2008 | 11:01 PM
durty's Avatar
Default rod bolts
i have been searching around here trying to find out if the rod bolts listed for a LS1 will work in a 4.8/5.3?...i found a set of brand new ARPs for 65$, so if they will work in my 4.8 im gonna pick em up
Old Aug 6, 2008 | 11:23 PM
Derek @ EDO's Avatar
FormerVendor
Yes, they will work.
Most guys get the ones for 100.00 AKA ARP2000's or the "cracked rod series"
Old Aug 6, 2008 | 11:35 PM
chevyguy7802's Avatar
+1 You'll be good to go with the arp's.......I went with them myself!
Old Aug 6, 2008 | 11:51 PM
durty's Avatar
134-6006, thats the part number on them, is that what you guys are using?
Old Aug 7, 2008 | 12:06 AM
durty's Avatar
over on ls1tech they say you need to resize the rods with he ARP bolts, how would they be any different than the katechs?
Old Aug 7, 2008 | 12:35 AM
134-6006 are the ones I bought......I didnt have to do anything to my rods they went right in!
Old Aug 7, 2008 | 07:06 AM
hirdlej's Avatar
What's wrong with the stock ones you have?
Old Aug 7, 2008 | 05:13 PM
durty's Avatar
nothing, just a precautionary measure, the motor is on the stand and figure i might as well do it while its out, the motor is going into a 96 gmc 2wd 4dr jimmy, TEA stage 1 241s milled .040(coming close to stock CC), custom comp grind 218/224 .563/.570 113+4, LS1 intake and a ported stock TB, it might like the RPM a bit, and i just would like to have the piece of mind knowing that the bottom end is a little stronger
Old Aug 7, 2008 | 05:16 PM
FormerVendor
No rod modifications are required. Be sure to remove the inner sleeve that surrounds the stock bolts, you will see what im talking about.
The bolts are a wise investment, cheap insurance!
Old Aug 7, 2008 | 05:47 PM
durty's Avatar
im hoping to make 350-375whp, eventually it will either get a remote mount turbo or a 125-150 shot....gotta see how fast this little 4.8 will go
what about head bolts?...stock are torque to yield right?...should i buy ARP head bolts or will stock replacement be alright?..
