Rocker Arms
Hey, i got a set of slp 1.85 roller rockers and might put them on the 5.3 instead of camming it for now, would i need a new set of springs for this? About how much would i gain
What does SLP recommend on the springs? The stockers are pretty much maxed out...well, stock. You'll be increasing the lift of the cam, I'd feel better running some yellow LS6's myself. Stock length pushrods should be fine, but you should check the swipe pattern on the top of the valve to make sure that the rockers are making the right contact.
budhayes3; do you know the mathematical equation to how it increases your cams lift , i kind of have an idea, correct me if iam wrong
lets say a .600 lift on a 1.7 rocker then to a 1.8 !
.600/1.7=0.35294117647
so
0.35294117647 X 1.8 =.63529411764 (.635)
so
That makes sense to me
