Rocker Arms
Old Feb 17, 2011 | 09:43 PM
bmd_CL's Avatar
Default Rocker Arms
Hey, i got a set of slp 1.85 roller rockers and might put them on the 5.3 instead of camming it for now, would i need a new set of springs for this? About how much would i gain
Old Feb 17, 2011 | 10:25 PM
bmd_CL's Avatar
bump, come on guys, i need help. this is the best place to get it
Old Feb 17, 2011 | 10:30 PM
Bluchevypick's Avatar
You shouldnt need springs but i recommend you checking your pushrod length.
Old Feb 18, 2011 | 02:20 PM
bmd_CL's Avatar
You dont think i would need springs? Even upgrading to a set of LS6s? And you dont think that the length would be 7.400 still?
Old Feb 18, 2011 | 02:35 PM
Your springs should be fine. You will need to check pushrods cause when you change the geometry it changes the length.
Old Feb 18, 2011 | 07:28 PM
budhayes3's Avatar
PT's Slowest Truck
What does SLP recommend on the springs? The stockers are pretty much maxed out...well, stock. You'll be increasing the lift of the cam, I'd feel better running some yellow LS6's myself. Stock length pushrods should be fine, but you should check the swipe pattern on the top of the valve to make sure that the rockers are making the right contact.
Old Feb 18, 2011 | 07:35 PM
1slowz71's Avatar
budhayes3; do you know the mathematical equation to how it increases your cams lift , i kind of have an idea, correct me if iam wrong
lets say a .600 lift on a 1.7 rocker then to a 1.8 !
.600/1.7=0.35294117647
so
0.35294117647 X 1.8 =.63529411764 (.635)
Old Feb 18, 2011 | 08:17 PM
mechan12's Avatar
That is The way
Old Feb 18, 2011 | 08:20 PM
budhayes3's Avatar
PT's Slowest Truck
.600/1.7=0.352411747
so
That makes sense to me
Old Feb 18, 2011 | 11:58 PM
bmd_CL's Avatar
so stock length pushrods should be ok, just maybe a set of hardened ones and a set of ls6 springs? how hard is it to adjust valve lash on these motors?
