rev limiter
Old Feb 23, 2013 | 12:02 AM
D.J Vasquez's Avatar
Default rev limiter
hey guys ! i have a problem with my burn outs !! and the engine is tacking way to high !! what msd box do i need to prevent that from happing ??or what should i do ?? i dont want to blow my motor !!
Old Feb 23, 2013 | 01:07 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
I'm not sure what you're asking here?
Do you want to raise or lower your rev limiter? If a rev limiter is set up properly, it actually HELPS you to not blow up your engine. The stock PCM can handle this task just fine, no need for an aftermarket device from MSD or anybody else.
Old Feb 23, 2013 | 07:50 AM
what i was saying was .i want it to not tack so high in the rmps when im doing a burn out !! i dont want to play with the pedeal ,i just want to hold the throttle down and concentrate on the burnout hope this helps !!
Old Feb 23, 2013 | 08:43 AM
https://www.performancetrucks.net/fo...64836-7853.jpg
Old Feb 23, 2013 | 11:17 AM
cams 98 silverado's Avatar
By chance do you have a valve body shift kit in place? first thing that came to mind is some shift kits can hold any gear to any rpm until you let off the gas. if your rev limiter was tuned to high and you have that sort of valve body setup then your gonna climb the rpms in one gear. OR... power shift that thing for a smokey burnout.
Old Feb 24, 2013 | 08:03 AM
come to think about{ cams 98 silverado } when my tranny went out i did up grade the valve body and clutches and bands !! as u can see i dont play with it much !! to get ues to the set up !! but power shifting sounds awsome !! thanks !! spring is around the corner !! so track time is a must ...
Old Feb 24, 2013 | 08:22 AM
stree racing - YouTube
Old Feb 25, 2013 | 08:04 AM
yeah... I mean as long as the trans rear end can take the abuse why not. a lot of time people use that shift kit where it holds to any gear if your using a ratchet shifter. man the feeling of those shifters is awesome.
Old Feb 25, 2013 | 01:58 PM
hog's Avatar
hog
Let off the accelerator a bit.
peace
Hog
Old Feb 25, 2013 | 02:28 PM
nonnieselman's Avatar
What are we working with here? a 98 civic or a silverado?
kinda left us in the dark on that one.
