Rev Limiter ?
Old Oct 15, 2005 | 09:32 AM
Bradazz's Avatar
Default Rev Limiter ?
Every now and then I hit my Rev Limiter on the 1-2 shift and sometimes the 2-3 shift only when I floor my truck, I had Jesse set my shift points at 5800 rpm with the rev limiter at 6200 rpm. With the Tow/Haul button my truck shifts @ 6000 rpm with the rev limiter at 6200 rpm. The problem seemed to start after I had my 3000 Stall Converter & 4.10 Gears installed which I had Jesse retune for those changes. I am thinking that I just need to set my rev limiter higher but I do not know what it should be set it at or if there is another problem I am overlooking.
Blwn99x
Mar 24, 2023 11:14 AM
Infernohoe
48
Oct 2, 2015 10:25 PM
nic351
Sep 24, 2015 09:43 AM
fortune46x
Sep 16, 2015 08:18 AM
TAPyvehc93
Sep 14, 2015 01:22 PM
