Replacing stock injectors with ?
Old Feb 24, 2009 | 04:55 PM
  #21
midnight_bowtie's Avatar
Like mentioned above, the stocks are good enough. If yours need replacement I would replace them w/ the stock 2002 inj. My 99 silvy came w/ the 19lbers as I believe yours did as well. I replaced mine w/ the 2002 24lbers. As mentioned, bigger doesn't necessarily mean better but 19lbs seemed to small for full bolt-ons.
Old Feb 24, 2009 | 08:15 PM
  #22
Truckshop's Avatar
if you happen to need some replacements i have a couple of stock sets lying around.
Old Feb 24, 2009 | 08:27 PM
  #23
nonnieselman's Avatar
i think i have 3 or 4 sets of stock injectors also..
Old Feb 24, 2009 | 09:06 PM
  #24
budhayes3's Avatar
PT's Slowest Truck
Not sure if the 00's had the 21lb or 24lb injectors, but I think only the 99's had the smaller ones. Hopefully someone who knows for sure can chime in. If by chance you do have the smaller ones and go with something bigger, remember that the PCM will need to be tuned for the larger injectors or you will run pig rich as the injector duty cycle doesn't need to be as high with the larger injectors.
OHsixLS3
Dec 27, 2016 09:30 AM
GrooveCityZ71
Aug 31, 2015 12:05 PM
sauldgold
Jul 23, 2015 02:15 PM
maxspeed05V
Jul 19, 2015 07:08 PM
gavin2005
Jul 16, 2015 12:09 AM
