Replacing stock injectors with ?
Old Feb 22, 2009 | 11:26 PM
GuiltyByAssociation's Avatar
Question Replacing stock injectors with ?
I've got a 2000 Silvy, 4.8L 2wd with minor mods (intake, wheatley tune, muffler and an 80mm tb) I've done some research on here and haven't come up with a good answer for a replacement.
Should I be looking for oem replacements or something a little better. I don't plan on doing a cam, nor doing anything other than lt headers possibly. What are your recommendations?
Thanks
Old Feb 22, 2009 | 11:32 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
if you are not maxing them out you dont need and wont gain anything by going to larger injectors.
Old Feb 22, 2009 | 11:33 PM
Mangled03gmc's Avatar
Baltimore Whore
Injectors won't do anything for your performance. Only time you need to up injector size is when you have the stockers maxed out. You sstill can mod a bit before you will be there..
Old Feb 22, 2009 | 11:35 PM
Okay thanks, should I go with OEM or does aftermarket brands have suitable replacements?
Old Feb 22, 2009 | 11:38 PM
Baltimore Whore
Oem..
Old Feb 22, 2009 | 11:44 PM
Thanks - one last question, where can I find a part number. I have several areas and have came up with zero results.
Old Feb 22, 2009 | 11:47 PM
Baltimore Whore
What size are you looking for, like stock lbs'rs for your engine??
Old Feb 22, 2009 | 11:49 PM
I would assume just bone stock, since my list of mods is very small... (see first post)
Old Feb 22, 2009 | 11:57 PM
Baltimore Whore
I wouldn't buy stock ones again unless yours a not working.. Maybe i am not understanding.. If you think your going to push it to the point of needing to upgrade, you want the delphi marine 42-44lbers..
Old Feb 23, 2009 | 12:04 AM
Okay so your recommending the Delphi marine 42-44 lber's, and I assume that I'd need a retune when upgrading to this?
The only other mod I might do is long tube headers, so I'd definitely need larger injectors?
