Replacement Motor
Old Jun 27, 2015 | 04:24 PM
mn1500's Avatar
Default Replacement Motor
I have a 74 Chevy 3/4 ton two wheel drive pickup and am looking to replace the older motor with a newer version 350. I like the one piece rear main seal and have read that the 96-99 5.7 Vortec motors have some real good flowing heads and make some good power with valve seats that can run unleaded gas. I would like to keep a carbureted motor so I am just looking for a long block. I see lots of motors on CL and have noticed a few come up advertised with the same problem. The problem I am seeing is low compression in one or more cylinders. They state the motors run but have low compression. Is this a common problem with this motor and if so what is the problem? How much damage has been done to these low compression motors? I dont want to buy something that is know for cracking heads and have to buy more heads to complete my conversion. I am also aware this is not enough information to diagnose a motor problem, I am simply asking if these 96-99 5.7 vortec motors have some known engine issues or if these are good donor transplant motors, and why a low compression issue?
Thanks,
Mike
Old Jun 27, 2015 | 05:04 PM
gamble686's Avatar
I would stay away from those years in general. They did have some very odd issues and have an extremely limited aftermarket support.
Old Jun 27, 2015 | 06:25 PM
mn1500's Avatar
Anyone know about the low compression problems with these motors? Also not sure on limited aftermarket supply. Since I want to use a carburetor all I need is a intake manifold and then select a cam, seems simple for the old 74 3/4 ton. Any additional advice on what the compression problems may be, or how the heads for thes 96-99 motors stand up?
Thanks again
OHsixLS3
Dec 27, 2016 09:30 AM
TXsilverado
Nov 26, 2015 10:54 AM
InsaneDomestics
Jul 27, 2015 02:42 PM
chevy1224
Jul 13, 2015 07:50 AM
