Replace LS1 with LS7
#61
with these specs, you really wouldn't need forged pistons unless you're running a LOT of boost.
505 horsepower @ 6200 rpm
475 lb.-ft. of torque @ 4800 rpm
7000-rpm redline
Unique engine block with larger 104.8-mm (4.125-inch) bores and pressed-in cylinder liners
Forged steel crankshaft with 101.6-mm (4-inch) stroke
Titanium connecting rods
Cast aluminum flat-top pistons
Racing-derived CNC-ported aluminum cylinder heads with titanium intake valves and sodium-filled exhaust valves
Dry-sump oiling system
11.0:1 compression ratio
Camshaft with 15-mm (.591-inch) lift
Hydroformed exhaust headers with unique "quad flow" collector flanges.
7000-rpm redline
lucas287
31
Jan 12, 2021 06:18 AM
SlvrSierra4.8
Oct 1, 2015 09:39 PM
