Removing Passenger side exhaust manifold
Old Apr 30, 2009 | 07:06 PM
Oldcrow's Avatar
Default Removing Passenger side exhaust manifold
How do you do it?
The oil dipstick goes between the manifold and it's mounting flange that bolts to the head
Old Apr 30, 2009 | 07:12 PM
outlawz2004's Avatar
remove bolt and pull out dipstick tube. Its tight, but will come out.
Old Apr 30, 2009 | 07:15 PM
Oldcrow's Avatar
You mean pull the tube out of the block?
That's what I figured but unsure, is it a bitch to get back in?
Old Apr 30, 2009 | 07:24 PM
viciousknid's Avatar
Where's the Beef?
Twist, don't jiggle. If you jiggle it you'll break it. I broke mine and it was in the pan for a couple months before it finally got where it could be pulled out during an oil change.
Try some wd40 around the block to see if it helps any.
happens some times.
Old Apr 30, 2009 | 07:27 PM
terravast4's Avatar
If you are careful it should come out and go back in easily
Old Apr 30, 2009 | 09:04 PM
Oldcrow's Avatar
That thing isn't coming out, it sure as heck isn't coming out easy.
4 winters of MN road salt isn't helping.
I'm giving up for the night. Sprayed it down with penatrating oil and try again tomorrow
zblee
63
Jun 10, 2023 01:25 PM
thunder550
Oct 8, 2015 04:53 PM
zblee
Aug 3, 2015 03:45 AM
Ketis
Jul 23, 2015 12:37 PM
