Radix Uber Alles
Old Dec 4, 2005 | 11:30 PM
CHarris's Avatar
Default Radix Uber Alles
Sometimes a man doesn't know his motor's limitations. This is one of those times.
The motor made a couple of thumps as I was coasting down to legal highway speed after a 60-90 mph blast. It almost seemed like a tire went down.... but then I got the check engine light.... and then a low oil pressure warning script across the driver info screen.... and, finally, I was coasting down in a whole other way.
See pics for what happened...
Here' s some math thrown in for fun-
2am + 6 miles from home = $100 tow bill
((Radix at 9 psi + cam) - big hole in oil pan)/ 10,100 miles = no warranty
LQ4 with 2 broken rods = front timing cover, oil valley cover, maybe rocker arms, and flex plate are the only reuseable parts from entire engine.
I'll think of some more witty stuff later, I'm sure.
Attached Thumbnails Radix Uber Alles-bottom-view-1.jpg   Radix Uber Alles-piston1.jpg   Radix Uber Alles-radix-uber-alles-1.jpg
Old Dec 4, 2005 | 11:39 PM
CHarris's Avatar
I'll be looking for low 13's with about 5 or 6 psi from the Radix come spring racing season
Old Dec 4, 2005 | 11:40 PM
kbracing96's Avatar
AH, that really sucks man! I hate it when a motor fails the oil pan test! (i.e. oil pan fails to contain parts inside)
Old Dec 4, 2005 | 11:41 PM
8ALTNG's Avatar
Wow. You sure showed that LQ4 who is boss Sorry man. That sux. What are the plans now????
Old Dec 4, 2005 | 11:57 PM
CHarris's Avatar
Crap happens...
plan is for more cubes... less boost New heads, but most likely not the WCCH heads. Not pleased with Mattrems results at all. It'll come together fast because holidays are coming and I want it done before then.
Old Dec 5, 2005 | 12:04 AM
CHarris's Avatar
I'll have some more pics once I get the engine out... those piston pieces are what I found laying inside the front edge of the pan... LOL
More horrors await.... Muh Ha Ha HA!
Old Dec 5, 2005 | 12:11 AM
CHarris's Avatar
I must say...
The fresh tranny rebuild and Yank 3000 felt AWESOME for the few hours that it was in before the big thump happened. Can't wait to roll that back out again
Old Dec 5, 2005 | 01:06 AM
thunder550's Avatar
High on diesel fumes
How much boost were you running? What are your cam specs?
Old Dec 5, 2005 | 01:09 AM
CHarris's Avatar
9 psi and the LPE GT2-3 cam
Old Dec 5, 2005 | 02:02 AM
TwoFast4Lv's Avatar
10 Second Club
It was impressive as hell while it lasted. Only time we had been in it that all four tires were lit up spinning looking for a direction
You just HAD to show that pink car who was boss...now you have to drive it
