Radix injectors?
Old Aug 23, 2005 | 10:55 AM
paw's Avatar
paw
Aklim, Will the plugs you mentioned let me use the 42lb injectors that come with the radix?
thanks
Old Aug 23, 2005 | 11:23 AM
Mort's Avatar
Cool
Yes you should be able to use the Radix supplied injectors and fuel rails if you buy the clips that fit the injectors. You will need to cut the clips off of the stock harness and solder on the new clips. Racetronix can supply the new plug ends (clips) for your new injectors as per aklim's post.
Old Aug 23, 2005 | 12:24 PM
zippy's Avatar
i just noticed that you have an underdrive pulley on your truck. don't use that with the radix.
Old Aug 23, 2005 | 05:43 PM
paw's Avatar
paw
So I need to put the stock pulley back on? I hope I did'nt throw it away when I cleaned out the garage.
What would happen if I did'nt put it back on?
How much would a stock pulley cost?
Old Aug 23, 2005 | 06:05 PM
zippy's Avatar
if you run an underdrive pulley with a radix you won't have much boost.
Old Aug 23, 2005 | 07:19 PM
Mr. Sandog's Avatar
I've also read about underdrive pulleys triggering the knock sensors, though that is not 100% likely, like underdriving the Radix pulley is.
Pimpinpete
43
Dec 22, 2017 08:13 AM
shootermwc
Oct 8, 2015 01:45 PM
sTNT971
Sep 26, 2015 04:22 PM
OHsixLS3
Sep 25, 2015 11:20 AM
bagged7104SS
Sep 24, 2015 08:42 PM
