Radix injectors?
Yes you should be able to use the Radix supplied injectors and fuel rails if you buy the clips that fit the injectors. You will need to cut the clips off of the stock harness and solder on the new clips. Racetronix can supply the new plug ends (clips) for your new injectors as per aklim's post.
shootermwc
Oct 8, 2015 01:45 PM
