Radix dyno graphs...
Old Feb 8, 2005 | 01:06 AM
retsell's Avatar
Default Radix dyno graphs...
Here are a two dyno pulls. Mods below. I couldn't find the third, but it looked the same, but was 409 hp instead of 405. We could hear detonation or a miss right where the hp started falling... prolly too much boost for 91 octane.
Old Feb 8, 2005 | 01:14 AM
Mr. Sandog's Avatar
Wow, very impressive. And a Mustang dyno no less.
Do you still have the stock 10-bolt? How is it holding up?
Also, do you have a link to that heat exchanger?
That is a sweet ride you have there Ryan.
Old Feb 8, 2005 | 01:18 AM
retsell's Avatar
It's just a small aluminum radiator from oreily's. I welded on some -AN fittings and brackets and went with it. Zacuto says its a bit overkill, which I prolly agree, but it was cheap... and much better than that tranny cooler that came with it.
Still a 10 bolt. 3 days after the tranny install it broke once. It had been howling for a while though. A carier bearing failed and the carrier shifted over and ground the **** out of the ring gear and pinion gear.
Old Feb 8, 2005 | 01:21 AM
1Blown04's Avatar
very sweet numbers. How is it driving a magnacharged truck with the 6-speed. I always thought that would be alot of fun with all the torque they make
Old Feb 8, 2005 | 01:34 AM
F8L Z71's Avatar
I'm really starting to hate these blowers.
Even with an auto those would be good #s.. Damn... Hahahaha
Old Feb 8, 2005 | 01:36 AM
retsell's Avatar
It's really really nice. I would like to find some slicks so I can see how hard it would pull in first and second, since they are kinda pointless. I am thinking of switching to a 4.11 gear instead of this 4.56. I went with the 456 cause I was towing with the truck, but I don't any more so....
Old Feb 8, 2005 | 01:38 AM
Mr. Sandog's Avatar
How tall is your tire?
Old Feb 8, 2005 | 01:43 AM
retsell's Avatar
So much for a "spike" huh?????????
retsell's Avatar
about 30"
275 45 20
Old Feb 8, 2005 | 01:55 AM
Mr. Sandog's Avatar
Originally Posted by retsell
about 30"
275 45 20
Right, with a 30" tire and 4.56's, your [2.66:1] First and [1.78:1] Second must zip by pretty quickly....
