radiator size
You should have a 34" radiator if you have a 6.0. You can measure it between the end tanks to get the legnth. Or if the radiator is bolted in the two outermost large holes on the top crossmember then its a 34", If the rad is bloted to the two inner bigger bolt holes then its a 26" I think.
Closer_2001
Sep 24, 2015 09:15 PM
