Racing at the track
Old May 7, 2003 | 06:08 PM
Syphon59's Avatar
Default Racing at the track
I've been racing at the track in various series and events for the past 4 years. In those 4 years I always raced a manual tranny. So I'm used to feathering the clutch while launching on street tires or doign high rpm launches on et streets(launching at 6000rpm with et streets in a mustang is fun ). So this will be my 1st time ever racing a automatic.
How do you all normally launch you trucks? Do you leave it in drive and stall as high as you can go? Do you stall it in 1st gear and launch and manaully shift it down the track? What do ya'll do?
Thanks
Old May 7, 2003 | 09:17 PM
Silvette_02's Avatar
Default Re: Racing at the track
Well, I've never been to the track, but here's what I do on the street :
I will drop it down in first, engage tow/haul mode. Then I stand on the gas and the brake. I have a 4.8L with 18's, so I don't spin ! It will remain at about 2200 rpms until I release the brakes. Then I just manually shift .
Practice a little before hitting the strip and you should be fine.
Josh Hucks
NXS Customs
Old May 8, 2003 | 03:10 AM
LS1TECH Sponsor
If you look at the band/clutch application chart a band and clutch hold the drum for first gear when in L1, opposed to only a clutch in D1 (drive). When I go to the drag strip I will use L1 and shift manually. And never do a neutral drop, i've heard storys of the "one way clutch" getting shot though the housing/body floor/drivers seat into a dudes ***.
Old May 8, 2003 | 07:06 PM
LIGHTNINROD's Avatar
We(Ls) leave it in Drive(o/d off) as the trans can shift better than I/we can. I brake-torque it up to about 900 rpms and then roll onto the the pedal and go WOT for the rest of the way.
Dan
walledition
Feb 24, 2026 03:27 PM
pewter00
11
Oct 20, 2023 05:40 AM
zblee
Nov 11, 2015 12:41 AM
dirt track racer 81
Sep 21, 2015 06:44 PM
Justin87gn
Sep 10, 2015 12:06 PM
