Superchip major problems!
Old May 5, 2003 | 08:04 PM
bigguy75inches's Avatar
Default Superchip major problems!
i just installed a custom tuned superchip for my 2002 whipple charged silverado 5.3
i bought it off a guy who had the same setup but got ls1 edit. now for my problem!
it wont run! is idles fine for about 5 seconds then the reduced engine power light comes on the the engine starts running bad and at about 450 rpm. giveing it gas does nothing! im at a total loss. it also does the same thing when i unload the custom programing! i guess my stock program is screwed? help!
Old May 5, 2003 | 08:18 PM
Default Re: Superchip major problems!
has anyone ever had their trucks computer reprogrammed back to stock cause they screwed it up before? Can a gm dealer do the reprogramming and how much did it cost?
Old May 5, 2003 | 08:47 PM
L-EATER's Avatar
11 Second Truck Club
Try unhooking the negative battery cable to clear the PCM. Check your e-mail too,
Old May 6, 2003 | 09:34 PM
Procharged LM7's Avatar
I had a superchimps fail in the middle of programming, and the truck wouldn't start, and the superchimps tune was stuck in there, even after disconnecting the battery cable(it ran though)stayed that way till I got Edit, and fixed it. They will fix the box for me, but not pay any shipping. They also said I could send them my PCM for re-flash. Yea right
their damn box doesn't even work, can I trust them with my PCM????
I would say after seeing this same problem at least five or ten times on the forums, I would stay away from them.
Good luck. Sam
Old May 6, 2003 | 10:35 PM
one03sierra's Avatar
Formerly one92rs
i had a hyper3 mess up on me. the dealer here reflashed my computer for $129.00.
Old May 7, 2003 | 10:31 AM
cdhd2001's Avatar
On two GM trucks, I have had pcm loss/failure caused by Hypertech PP3's. I now have two Superchip tuners (one regular, one for the Powerdyne) and have not had a problem with either. Do a search on the www.pickuptruck.com website for more info.
Old May 7, 2003 | 10:35 PM
In the middle of programming my 2000 with Superchips it locked.I pulled my PCM out sent it to them,they reflashed it and I never had a problem since(until a friend of mine took out a Toyota with my truck).My 2002 has been fine.I think the problem with my 00' was my cell phone was plugged in They say make sure there is NO drain on the battery.
Old May 7, 2003 | 10:50 PM
i ended up having to tow my truck to the nearest dealer.
they were going out of business and only charged me 32.50!
to reflash my computer! i was very happy! they didnt even charge me to put a code scanner on it to locate the prob. every where else was going to charge 50 buck just to look at it. then who knows how much to reflash!
too bad that dealer is shut down now.
Old May 8, 2003 | 07:10 PM
LIGHTNINROD's Avatar
my truck has been idling at like 300rpm for the past two weeks. took it into the dealership, they reset everything. then they said they couldnt locate the problem and it still does it . ohwell it was under warranty
You may(probably?) have a dirty or worn IAC(Idle Air Control) valve. It's easy to remove and soak/flush with brake or carb. cleaner and reinstall. If it's worn, the replacement is in order.
Dan
madmann26
Apr 29, 2020 09:17 AM
dsbodley
Nov 14, 2015 09:46 PM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
chvy=power
Sep 28, 2015 10:32 AM
