quick question fellass..
Old Mar 16, 2011 | 08:33 PM
95yukonGT's Avatar
Default quick question fellass..
i have a 94 yukon. its a 350 with tbi. I wanted to put a carb on it. Just a 4bl arb caus epeople were saying id get better gas mileage. Is that true? is it hard? thanks
Old Mar 16, 2011 | 09:01 PM
1Bear's Avatar
Gas mileage aside, it is easy to install a carburetor on a TBI equipped 350 should you decide to do so. Basically, just install a carbureted intake manifold, carburetor, an older style large cap HEI distributor and a fuel pressure regulator to cut down the pressure that the factory electric fuel pump put out to a level that whatever carburetor you install will need or you will lift the needle(s) of the seat and flood the engine.
Old Mar 16, 2011 | 09:05 PM
mhotrodscooter's Avatar
I had a 94 blazer with 230k with 32's and got almost 18mpg on highway.. With a couple mods. As far as putting a carb & getting better mpg. It would take some fine tuning but it could be done. Is it worth the trouble I doubt it.
Old Mar 17, 2011 | 07:20 PM
95yukonGT's Avatar
sounds very eassyyy. Deff would get everything i need. Maybe come time in the future ill do it then.
People say the TBI is **** and its jsut worth putting the carb on it. I have 33s on mine and gas mileage is horrible. im not lifted though.
Justin87gn
Sep 10, 2015 12:06 PM
custm2500
Sep 8, 2015 05:53 PM
bisqikss
Sep 8, 2015 03:35 AM
SWINGRRRR
Sep 3, 2015 07:49 PM
mr03silverado
Sep 2, 2015 11:43 PM
