Quick question about removing/replacing oil pumps on our trucks
Old Mar 8, 2009 | 12:18 PM
hirdlej's Avatar
Default Quick question about removing/replacing oil pumps on our trucks
With my upcoming cam swap I'm going to be replacing the timing chain and gear set on my 6L. For those of you who have changed oil pumps out in the truck, is it really necessary to lower the front of the oil pan to get at the pickup tube bolt? Would a 90deg gearwrench get in there ok? It's been since last fall since I looked behind the front cover of my motor so my memory is getting to me.
Old Mar 8, 2009 | 12:53 PM
l_kusler's Avatar
I haven't pulled mine personally, but i don't think the bolt would really be a problem to get out with the right wrench. However the pickup tube in the pump would hinder removal. The pump assembly has to slide out straight off the crankshaft snout. The tube is in the pump and at 90 degrees from the crank. So without bending the pump tube being that its bolted rigid to the windage tray it doesn't look like you could pull it off.
I could be wrong, but thats what i saw when i had mine open, heres an old pic i dug up.
Attached Thumbnails Quick question about removing/replacing oil pumps on our trucks-cv.jpg
Old Mar 8, 2009 | 05:02 PM
quicksilverado's Avatar
I swapped mine in the truck a couple of years ago. Seems like I unbolted the oil pan to do the swap. It was still tough.
5.3lSilverado
25
Aug 29, 2016 12:48 AM
The_W
Oct 28, 2015 09:00 PM
black6spdz
Jul 16, 2015 01:32 AM
abey15
Jul 13, 2015 02:20 PM
Mzay
Jul 6, 2015 11:03 PM
