Quick NGK TR55 question
Old Aug 20, 2005 | 02:53 PM
4.8shorty's Avatar
Default Quick NGK TR55 question
I just bought a set. When I asked the guy at the counter if I had the right one for my truck, he gave me a # diff. then on the package. I told him I knwe that I needed TR55s, so he said it should work fine. Now that I'm ready to put them in, they're about 1/4" longer then the stockers! Can I still use them? I can just emagine totally destroying the engine by changing the plugs. That would be just my luck.
Old Aug 20, 2005 | 03:06 PM
14 Second Truck Club
I am using them without any problems.
Old Aug 20, 2005 | 03:14 PM
4.8shorty's Avatar
Just hoping that TR55s don't come in diff lengths.
I'm going to cross my fingers and hope for the best.
Also working on TB bypass. Anyone know for sure
what size hose that is?
Old Aug 20, 2005 | 03:29 PM
99Silver6.0's Avatar
Just tell him you want some plain old TR55's. Thats all you need. He was probably trying to pawn some of them expensive Iridium plugs off on ya.
Old Aug 20, 2005 | 04:04 PM
TURBHOE's Avatar
just unhook it from the right side of the tb and plug that hose in where the one is comming of the block. its easier than doing all that other crap. it work for mine and still has.
Old Aug 20, 2005 | 04:21 PM
Okie5.3's Avatar
what is the part number, 3951? if so your good to go.
Old Aug 20, 2005 | 05:04 PM
4.8shorty's Avatar
Not sure about the part #, threw the packing out after changing them. It started no problem, so I'm guessing everything is ok. It just took me an hour, $20 for plugs, $20 for 3/8 swivel extension, two trips to the auto parts store, and busted knuckles... but at least I did it myself!!! Yah, the back passenger side one was tricky. A 3" extension was too long and no extension didn't work. I looked for a 2" or 1" but no such thing. Ended up getting the swivel. Thanks for the help guys, and 4.8T I'm going to have a look at that tonight and see if I can rig up what you described. I've got a 3/8"ID union I think might do the trick if not. Thanks again!!
Old Aug 20, 2005 | 05:08 PM
TURBHOE's Avatar
on that back one i figure out just use a socket on the sparkplug socket and it works perfect. oh and not a problem.
Old Aug 20, 2005 | 06:10 PM
I think I used a 1/4" double hose barb. ANd for the back plug I used the plug socket with a wrench.
Old Aug 20, 2005 | 08:31 PM
4.8shorty's Avatar
Damn, those are two good ideas. I wish I would have thought of that before throwing twenty bucks away. As for the TB bypass, I'm thinking I might try to have something in there permanent that I can just switch over twice a year. Like having a three way valve setup or something. Sould be easy enough, and would prevent me removing my cold air intake. What do you guys think? Oh, and sorry about filp-floping on the forum subject.
