Quick! I need the tightening pattern for the oil pan!
Old May 28, 2006 | 09:34 AM
FarmerBeau's Avatar
Sexy Party Mod
Default Quick! I need the tightening pattern for the oil pan!
I ran a search and found nothing so does anybody have this info or does it matter. I have the torque specs and all but i think i left my ls1 book back up at my house at college. Im doing a camswap today at 1:00 so i kind of need this info rather fast!
Old May 28, 2006 | 09:52 AM
RoosterMcCandles's Avatar
I don't know for sure but the oil pans I have put back on I just used a star pattern kind of like on the lug nuts and I never had any problems. I wouldn't think it would make a huge difference as long as it is sealed well around the gasket.
Old May 28, 2006 | 10:18 AM
FarmerBeau's Avatar
Sexy Party Mod
I was thinking the same but, cody (1slow01Z71) told me that he had the diagram and i just wanted to be certain. Thanks for the info though!!!
Old May 28, 2006 | 12:10 PM
thunder550's Avatar
High on diesel fumes
Why are you dropping the oil pan for a cam swap? I just started in the middle, alternated back and forth and worked my way towards the outside....
Old May 28, 2006 | 03:17 PM
BigBlockChev572's Avatar
He's putting an LS2 Chain on. Just be careful to not overtighten the two long rear bolts, they strip easy.
Old May 28, 2006 | 03:43 PM
There is a pattern, but kind of hard to show or explain what it is on here. But....you start in the middle, go from one side then the other (L to R), then move your way toward the back until you have tightened all. Then work your way to the front in the same fashion. 18ft lbs.
FWIW, I've had mine either off or dropped some and have never used the pattern and no leaks. Not recommending that, just relaying my experience.
Old May 28, 2006 | 04:05 PM
1SlowHoe's Avatar
Destroyer of Transmissions
From ls1howto.com....
Now, retighten up the oil pan bolts. The smaller bolts get torqued to 106 INCH lbs, or about 9 foot lbs, while the bigger bolts get torqued to 18 lb/ft. Note: You WILL break those smaller headed bolts if you go past the 9 lb/ft as specified.
http://www.ls1howto.com/index.php?article=23
No pattern was specified, I checked a couple of places.
Old May 28, 2006 | 04:18 PM
The pattern came from a Haynes manual.
Old May 28, 2006 | 06:32 PM
Zick's Avatar
My "How to build LS1" book says to tighten them down in a radial pattern starting with the center bolts.
Chavette
Oct 28, 2015 07:33 PM
FormulaZR
Sep 14, 2015 05:23 PM
Go5.3tt06
Sep 14, 2015 02:11 PM
2004gibbstruck
Sep 7, 2015 06:05 PM
