Quick! I need the tightening pattern for the oil pan!
Old 05-28-2006, 09:34 AM
Sexy Party Mod
FarmerBeau's Avatar
Default Quick! I need the tightening pattern for the oil pan!
I ran a search and found nothing so does anybody have this info or does it matter. I have the torque specs and all but i think i left my ls1 book back up at my house at college. Im doing a camswap today at 1:00 so i kind of need this info rather fast!
Old 05-28-2006, 09:52 AM
RoosterMcCandles's Avatar
I don't know for sure but the oil pans I have put back on I just used a star pattern kind of like on the lug nuts and I never had any problems. I wouldn't think it would make a huge difference as long as it is sealed well around the gasket.
Old 05-28-2006, 10:18 AM
Sexy Party Mod
FarmerBeau's Avatar
I was thinking the same but, cody (1slow01Z71) told me that he had the diagram and i just wanted to be certain. Thanks for the info though!!!
Old 05-28-2006, 12:10 PM
High on diesel fumes
thunder550's Avatar
Why are you dropping the oil pan for a cam swap? I just started in the middle, alternated back and forth and worked my way towards the outside....
Old 05-28-2006, 03:17 PM
BigBlockChev572's Avatar
He's putting an LS2 Chain on. Just be careful to not overtighten the two long rear bolts, they strip easy.
Old 05-28-2006, 03:43 PM
There is a pattern, but kind of hard to show or explain what it is on here. But....you start in the middle, go from one side then the other (L to R), then move your way toward the back until you have tightened all. Then work your way to the front in the same fashion. 18ft lbs.
FWIW, I've had mine either off or dropped some and have never used the pattern and no leaks. Not recommending that, just relaying my experience.
Old 05-28-2006, 04:05 PM
Destroyer of Transmissions
1SlowHoe's Avatar
From ls1howto.com....
Now, retighten up the oil pan bolts. The smaller bolts get torqued to 106 INCH lbs, or about 9 foot lbs, while the bigger bolts get torqued to 18 lb/ft. Note: You WILL break those smaller headed bolts if you go past the 9 lb/ft as specified.
http://www.ls1howto.com/index.php?article=23
No pattern was specified, I checked a couple of places.
Old 05-28-2006, 04:18 PM
The pattern came from a Haynes manual.
Old 05-28-2006, 06:32 PM
Zick's Avatar
My "How to build LS1" book says to tighten them down in a radial pattern starting with the center bolts.
Chavette
10-28-2015 07:33 PM
FormulaZR
09-14-2015 05:23 PM
Go5.3tt06
09-14-2015 02:11 PM
2004gibbstruck
09-07-2015 06:05 PM
Quick Reply: Quick! I need the tightening pattern for the oil pan!
