Questions on in-line pump placement and fuel filter thread size.
Old Oct 21, 2005 | 08:59 AM
TG02Z71's Avatar
Default Questions on in-line pump placement and fuel filter thread size.
Going to be installing the in line pump I bought from Allen Nelson soon and was wondering if it really matters if I mount it before or after the fuel filter.
I'm thinking after would be better to keep crap out of the pump.
Also what size are the threads on the fuel filter and what type are they?
Thanks all!
Old Oct 21, 2005 | 01:35 PM
TG02Z71's Avatar
up up up we go back to the top.
Old Oct 21, 2005 | 02:55 PM
TG02Z71's Avatar
Here is what i got from Allen for $180.00.
I threw the caliper in for scale.
Can I or should I even use the barbed type fittings or is there a stainless braided alternative that will let me go from the filter to the pump then from the pump outlet to the existing line where the filter outlet was?
Old Oct 21, 2005 | 05:53 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Someone respond so I can compy his setup
I didnt know allen sold fuel pumps. Im going to be buying my injectors from him soon I may jsut go ahead and order the fuel pump also.
Old Oct 21, 2005 | 06:51 PM
TG02Z71's Avatar
Thanks for the TTT dude!!
Old Oct 22, 2005 | 10:36 AM
Mort's Avatar
Cool
I just cut a section out of the steel fuel line after the filter toward the front of the truck and put mine it there. The filter should probably be after the pump but unless the pump starts spitting out parts then it should not really matter. I used the barbed fittings on the pump and double clamped the hose onto the existing steel fuel line. Use the clamps made for fuel line connections if possible.
If you find a better way let us know because I have been thinking about re-doing mine.
Old Oct 22, 2005 | 02:25 PM
vanillagorilla's Avatar
ttt for ya, any one else? Any pics? What does the Radix setup look like. It looks like this could be done similar. Pics damn it!!!!
Old Oct 22, 2005 | 03:38 PM
TG02Z71's Avatar
Pics or part numbers would be cool.
Jim I thought about cutting into the line but 65psi of fuel pressure just makes me a little nervous going through a rubber tube with hose clamps on it, I guess I'm a chickenshit.
I'm going to take my filter and new pump to the hardware store and see what size fitting will plumb into either of them. They don't usually have any automotive parts there but the guys at most auto supply stores are useless.
The Walbro pump has a straight threads in it that are almost the same diameter and pitch as a 1/8-27 pipe thread.
I tried looking on Summit's site but most are AN style fittings and the rest have little to no description or pics to reference.
TTT again.....
Old Oct 23, 2005 | 07:36 PM
TG02Z71's Avatar
Anyone else have an in-line pump?? I still can't find anything as far as parts or thread sizes go. Even looked over on LS1TECH and found nothing worth mentioning.
If I do get anything I'll be sure to post pics of my final set up and parts bought.
Old Oct 24, 2005 | 02:31 PM
TG02Z71's Avatar
Found this site but still don't know what size threads I need to adapt one to the other.
paragonperformance.com
thunder550
Oct 8, 2015 04:53 PM
lxcoupe
Jul 21, 2015 02:12 AM
GMCtrk
Jul 17, 2015 06:39 PM
76k10chase
Jul 17, 2015 01:48 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
