questions about LS1 Edit
Old Feb 7, 2003 | 01:29 PM
14 Second Truck Club
Default questions about LS1 Edit
With LS1 Edit can you...
-raise rev limiter
-raise/lower shift points
-raise top speed limiter
-recalibrate speedometer/odometer for gear ratios (like going from 3.42 to 4.10)
I think it can do all of these, I just want to check. I might be able to get a laptop for real cheap if I do I want to get LS1 Edit.
Old Feb 7, 2003 | 01:57 PM
11 Second Club
Default Re: questions about LS1 Edit
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 99silveradoSS:
<strong> With LS1 Edit can you...
-raise rev limiter
I think it can do all of these, I just want to check. I might be able to get a laptop for real cheap if I do I want to get LS1 Edit. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">All that and alot more. reduce TQM, adjust A/F ratio, add more timing, firm shifts up,the list goes on.Its worth every penny. If you can find someone close to you with a licsense left on thier cable that would be cheaper. Draw back to that is you have to get the cable from them to tune.
Old Feb 7, 2003 | 02:16 PM
MR.QUIK's Avatar
WORKINPROGRESS R THEY HARD 2 WORK WITH BEING I don't know **** about computers <img border="0" alt="[bang head]" title="" src="graemlins/gr_banghead.gif" />
Old Feb 7, 2003 | 06:22 PM
FarmTruc's Avatar
Performance Trucks Sponsor
LS1Edit does have a little learning curve to it, you need a laptop, and you need a daig tool, ease or autotap are fine.
The mailing list is basically ****, a lot of new comers asking the same old questions, which could be avoided if those guys would get on a forum, archives.
YOu'll need to learn what all the tables and adjustments do, good luck finding a straight answer. you;ll get sarcasm or no answer at all.
the good think is you can do anything you want as far as adjustments and if they don't work, simply start over.
there are no good manuals or sites that just staight up tell you how to do something, i'm trying to get mine going, workingprogress and i did his and it's been a learning exper.
you'll definitely benefit from edit, it blows all other out of the water, predator, hpp3, diablo.
later,
allen
Old Feb 7, 2003 | 06:38 PM
redaddiction's Avatar
it is worth it i have it and i love it and it does do alot of stuff
marc
Old Feb 7, 2003 | 06:45 PM
Texas Terminator's Avatar
11 Second Club
modify anything (almost), makes a huge difference (if used correctly) and is fun to jack with. it definately will take awhile to get the hang of, it's pretty intense.
zblee
63
Jun 10, 2023 01:25 PM
nrmskate
Aug 11, 2015 02:44 PM
USMCvet0311
Aug 1, 2015 07:45 AM
Black-Syde
Jul 6, 2015 02:12 PM
