questions about 5.3L and 4.8L's
Old Apr 2, 2005 | 04:27 AM
Apex_632's Avatar
Default questions about 5.3L and 4.8L's
sup guys. just curious...will ls1 heads fit on the 5.3 v8 and the 4.8 v8's? and also if i'm looking up cams..do i have to specifically look it up for the 5.3 and 4.8's..or do cams that work for ls1's work in the truck motors as well?
Old Apr 2, 2005 | 05:32 AM
zippy's Avatar
the LS1 engine is a gen III small block. the LR4 and LM7 are also. the parts for it interchange just like the did on the gen I small block. the LS1 heads will fit on the smaller bore LR4 and LM7, but the compression will take a hit since the chamber for the LS1 head is larger. there isn't much of a good reason to switch to heads from the 5.7.
Old Apr 2, 2005 | 05:46 AM
Apex_632's Avatar
i figured since they more then likely outflow the lm7 heads n such it'd be a good reason to do it.i have no clue how well the stock heads on the trucks flow either.
Old Apr 2, 2005 | 05:47 AM
zippy's Avatar
the stock 4.8/5.3 heads do pretty well in stock form. the main difference as far as flow goes between them and the 5.7 head is in the intake valve sizing. the 5.7 has a larger intake valve.
5.3lSilverado
25
Aug 29, 2016 12:48 AM
USMCvet0311
Aug 1, 2015 07:45 AM
projectnightcrawler
Jul 19, 2015 11:30 PM
FlowmasterMufflers
Jul 17, 2015 03:26 PM
