questions about 5.3L and 4.8L's
sup guys. just curious...will ls1 heads fit on the 5.3 v8 and the 4.8 v8's? and also if i'm looking up cams..do i have to specifically look it up for the 5.3 and 4.8's..or do cams that work for ls1's work in the truck motors as well?
the LS1 engine is a gen III small block. the LR4 and LM7 are also. the parts for it interchange just like the did on the gen I small block. the LS1 heads will fit on the smaller bore LR4 and LM7, but the compression will take a hit since the chamber for the LS1 head is larger. there isn't much of a good reason to switch to heads from the 5.7.
5.3lSilverado
25
Aug 29, 2016 12:48 AM
GXPJAY
Jan 27, 2016 11:45 AM
FlowmasterMufflers
Jul 17, 2015 03:26 PM
