Question for you engine swap fellas.......
Old May 22, 2003 | 05:50 PM
CHAGO's Avatar
Default Question for you engine swap fellas.......
Lets say I was to swap my 4.8 for a 6.0....
(note I have an '03 / the motor is a '00)
The 6.0 is pretty much complete with the exception of an intake and some other little things....would this motor just drop right in, connect everything and be driveable, or would I need to worry about anything computer related?
Your responses are needed ASAP!!
Thanks
Old May 22, 2003 | 08:42 PM
redaddiction's Avatar
Default Re: Question for you engine swap fellas.......
Yes it would be driveable but You would need to get it tuned for maximum performance The bad thing is that you have an 03 but it would work and i would suggest getting ls1 edit when it becomes available for the 03's
Marc
Old May 22, 2003 | 09:37 PM
BigTex's Avatar
The 99 and 00 6 liter motors do not physically fit into our trucks (at least as a drop in and run replacement). They have a longer crank and will bind up the the converter into the transmission. Do a search about this issue on this forum. Plus the 00 models had iron heads and the 01+ 6Ls have good flowing aluminum heads.
Basically, stay away from those 6L motors. There are qute a few floating around, and they aren't worth near as much as the newer ones.
Old May 22, 2003 | 10:33 PM
CHAGO's Avatar
The person selling it says they are aluminum heads, and says the block will go right in.
Old Jun 4, 2003 | 12:53 PM
IslandTahoe's Avatar
If I have a 00 5.3L now and want a simple 6.0L drop in swap, which year am I looking for?
Old Jun 4, 2003 | 01:15 PM
IslandTahoe,
You would need a 2001+ 6.0L for a simple swap.
Old Jun 4, 2003 | 05:12 PM
SleekSilverado's Avatar
Im going from 02 5.3 to 01 6.0 block what is interchangable??? Computer wise and mechanical..... Any help is appreciated
Old Jun 4, 2003 | 06:02 PM
CashDudeHomie's Avatar
03 pewter see if it has LS1 heads. If it does then don't buy it because he might have swapper the iron for the aluminum. That is what happened with that one guy on here and he got screwed.
Old Jun 5, 2003 | 09:28 AM
little help anyone???
Old Jun 5, 2003 | 12:05 PM
Banned
sleek, it'll be a direct replacment in your case and will run with stock program but you will need tuning to make it run GOOD.
5.3lSilverado
25
Aug 29, 2016 12:48 AM
GrooveCityZ71
Aug 31, 2015 12:05 PM
creekrat
Aug 2, 2015 01:27 AM
Mark_k
Jul 9, 2015 12:37 AM
