question about flex a lite VSC.
Old Mar 27, 2005 | 07:22 PM
Default question about flex a lite VSC.
i got my flex a lites mounted but i dont have them wired up yet...i was wanderin if i will have to reprogram the pcm to make these fans work? or do i just have to wire up the VSC and they will work? thanks!
Old Mar 27, 2005 | 07:32 PM
v8
17,16,15,14,13,12,11 Drvr
if you use there vsc then no you dont need to reprogram your pcm.
Old Mar 27, 2005 | 08:32 PM
therock's Avatar
Default You are going to hear lots of flak on the FAL Vsc.
The VSC's have a history of crapping out. I don't know what version you have or how much FAL has done to remedy VSC problem, but I do know they were busting hump trying to make their products work and save their reputation. They are good folks and will take care of you. But you gotta call them. The suppliers where they got their stuff put the screws to them. They finally fixed the melting fuse & holder problem with a smaller hard plastic plug in fuse holder. If you have the one with a soft rubber fuse cover call FAL.
After I did the following I had several hot summer months of trouble free operation and got a new truck and sold them.
It is VERY important that the main + & - connections be made to the battery posts in any fuse holder type of setup. These fans really move some air so they pull current. Don't ground to the frame, go to the battery. Don't hook the positive anywhere but to the battery.
I had the audio shop type of gold plated side post replacement bolts that have a nice 3/8" bolt on the end for other connections. You can get large wire eyelet crimp connectors from an audio shop also.
Also if you decide to try the FAL setup, make sure the VSC connections are tight. If they are still the Sta-Con type and they slide on too easily, just crimp them a hair to get a good tight fit. Also put some tape over the temp adjustment hole when you are finished with the install and setup.
If I had to buy their fans again knowing what I do now, I would call them and let them know I have heard all the bad press about their VSCs' being unreliable and am not very confident rather or not they will strand me out on the road. And If they did not convince me I would ask for a refund on the VSC and go get a Delta or Nelsonperformance.com harness. You paid for the VSC why toss it and but another. Hear them out. Let us know.
Good Luck.
Old Mar 27, 2005 | 08:39 PM
closet red neck's Avatar
I went through 3 VSC's and finally wised up and got a Nelson harness!
Old Mar 28, 2005 | 12:39 AM
gametech's Avatar
I had the melting fuse holder, then the vsc crapped out on me driving between Laredo and San Antonio last summer. The guy from FAL sounded very sympathetic on the phone when I told him what happened, and by the next day when I arrived in Beaumont they had overnight shipped a replacement. I originally ordered the fans through Summit, so by the time I got back to Atlanta I had a spare that Summit shipped to my house. Since I now have a spare, as luck would have it, I have had no more problems.
blownss27
Aug 14, 2020 08:27 AM
Alco
Sep 4, 2015 04:08 PM
Tigger Welder
Sep 2, 2015 08:17 AM
RS/SS 4.8
Aug 2, 2015 11:03 PM
USMCvet0311
Aug 1, 2015 07:45 AM
