Pushrods out of order, does it matter?
Old Jun 16, 2005 | 03:17 PM
RyPkr_99's Avatar
Default Pushrods out of order, does it matter?
I'm swapping engines here shortly and the longblock I've acquired does not have the pushrods marked as to where they went. It also does not have rocker arms. Should I buy brand new arms and rods or will used ones out of order work? If they work will they cause excessive noise?
Old Jun 16, 2005 | 04:20 PM
pushrods don't have to be put back in the same order. but make sur you get the rocker arms back in the same order.
Old Jun 16, 2005 | 06:15 PM
RyPkr_99's Avatar
The haynes manual says both. Regardless of whether or not the pushrods do I guess I'm buying brand new rockers huh?
Old Jun 16, 2005 | 06:34 PM
hemi38ram's Avatar
pushrods do need to be put back in the same order, as they wear just as the rockers do.
Old Jun 16, 2005 | 08:31 PM
RyPkr_99's Avatar
I guess I'll plan on getting new of both. What would happen if one were to install them all out of order though?
Old Jun 17, 2005 | 04:15 AM
hemi38ram's Avatar
valves would open too much or too little causing the engine to breathe funny.
Old Jun 17, 2005 | 11:09 AM
warpwr's Avatar
I think they are all adjustable rocker arms, aren't they? I'm doubting that .0001-5 of wear will change anything once they are adjusted.
Old Jun 17, 2005 | 11:12 AM
Mangled03gmc's Avatar
Baltimore Whore
Push rods no but if you use the connecting rods make sure they go back on the same way.
JordanH
Nov 6, 2015 07:42 PM
JordanH
Oct 3, 2015 03:59 PM
Wolftrk99
Oct 2, 2015 08:17 AM
Velocity1
Oct 2, 2015 08:01 AM
