Pushrod lenght ?
Old Feb 11, 2014 | 07:30 PM
BlackRCSB's Avatar
Default Pushrod lenght ?
Okay guys. I'm getting a comp cam 212/218 114 LSA LOWLIFT VERSION. Made my mind on getting a set of blue ls6 springs from scoggin dickey, but I'm confused on what pushrods to get. I'm getting them from texas-speed.com. What length and diameter should be ideal for my setup ?
Thanks for any help guys.
Old Feb 11, 2014 | 08:01 PM
Atomic's Avatar
I have a gauge for that
Buy the pushrod checker tool and measure for what you need, dont guess.
Old Feb 11, 2014 | 08:03 PM
oakley6575's Avatar
Old Feb 11, 2014 | 08:45 PM
BlackRCSB's Avatar
Que, Que ?!?! Lmao
Old Feb 11, 2014 | 08:51 PM
Chevy_King1500's Avatar
Originally Posted by BlackRCSB
Que, Que ?!?! Lmao
if everything else is stock a 7.400'' pushrod will be fine
Old Feb 11, 2014 | 08:54 PM
AUTOT3K's Avatar
measure it, the tool is about $20 and takes 15 minutes to check a couple cylinders
however the diameter you need is 5/16"
Old Feb 11, 2014 | 09:49 PM
craigsix's Avatar
you get a more accurate reading with a soft spring made for checking pushrod length. i think your stock pushrods would be ok for your setup. just put them back in original spots they came out of.
Old Feb 11, 2014 | 10:04 PM
Atomic's Avatar
I prefer to go with 3/8" pushrods if they have them in the length I need, especially with setups with a lot of spring pressure. Larger diameter pushrods are much stiffer.
SS94S10
Jan 3, 2019 01:57 PM
JordanH
Nov 6, 2015 07:42 PM
jtphelps289
Sep 29, 2015 12:00 PM
LARRY01Z28
28
Sep 28, 2015 07:54 AM
97_ek
Sep 23, 2015 09:16 PM
