pulsing....????????
Old Dec 21, 2004 | 09:35 PM
onyx's Avatar
14 Second Truck Club
Default pulsing....????????
when the truck is in park, the RPM's will bounce from 600 to 900 rpm's... also i hear a clicking, like the fan is turning on and off.
Old Dec 21, 2004 | 09:38 PM
BlownChevy's Avatar
blownerator
25 Year Member
Is it your fan?
Old Dec 21, 2004 | 10:05 PM
onyx's Avatar
Originally Posted by BlownChevy
Is it your fan?
dunno, never bothered to get out and check...
Old Dec 21, 2004 | 10:35 PM
Stroker 1500's Avatar
defroster on?? sounds like ac compressor
Old Dec 21, 2004 | 10:36 PM
Ryan23silverado's Avatar
compressor relay gone bad maybe?
tune?
EDIT: ahh, you beat me by a few seconds there.
Old Dec 21, 2004 | 10:39 PM
As far as the tune goes, there is logic programmed to increase idle speed if the ac compressor is on. If it is in fact cycling on/off then that is most likely the reason for the rpm variation.
Old Dec 22, 2004 | 04:50 AM
onyx's Avatar
a/c isnt on, but the defroster is, but on heat.... i'll turn everything off and see what happens..
Old Dec 22, 2004 | 10:22 AM
Flyer's Avatar
Is it happeneing real quick, kinda like a lope, but hard and quick.
Old Dec 22, 2004 | 11:10 AM
BigTex's Avatar
Just an FYI - the A/C compressor goes on when the defroster is running even on high heat. The compressor de-humidifies the air so you don't fog up. So your idle issue is caused by the A/C compressor which triggers higher idle rpms in the PCM.
Old Dec 22, 2004 | 12:35 PM
could have a short cycling compressor due to a low a/c charge
Tex is right on.
