pulling 2nd too high??*VIDEO*
Old Mar 21, 2006 | 06:33 PM
TXsilverado's Avatar
Default pulling 2nd too high??*VIDEO*
i know its multimedia but its still a performance question...
after watching this video it sounds like i could be trying to hold 2nd for too long...it just sounds dead at a certain point and ive never noticed it from inside the truck. maybe i could pull 1st a little farther? what do yall think?
2nd shift too high?
Old Mar 21, 2006 | 06:40 PM
BlackLM7's Avatar
It's difficult to hear your truck. It sounds like you could shift later in 1st and sooner in 2nd. I'm sure you know this already...if you don't feel your truck pulling anymore, you've shifted too late. Did you manually shift your truck in the video?
Old Mar 21, 2006 | 06:55 PM
1-2 is shifting at 6200
i manually shifted the truck on the 2-3 shift so i have no clue exactly what rpm it was at. its tuned to shift 2-3 at 6000 rpm but the tach only makes it to 5800 before the shift and i think it has just a lil more in it. i manually shifted when the tach hit the 6k mark.
Old Mar 21, 2006 | 07:31 PM
TravisH's Avatar
my truck does the same thing. If I manualy shif it up to 6k it sounds dead. it shifts at 5800 normally. I think it is the tune..
Old Mar 21, 2006 | 07:41 PM
FarmerBeau's Avatar
Sexy Party Mod
yea it does sound like it went dead, you might try getting Allen to lower your 2-3 shift points.
BTW Good vid, i missed you kickingthat stang the other night cuz i think i was a truck or two ahead of you. Great kill!!
Old Mar 21, 2006 | 08:56 PM
Full_Pull6.0HD's Avatar
it well could be the position of your truck with respect to the camera. It would be interesting to see if it had the same "dead spot" sound if it wasn't passing the camera just as it was coming to the top of second. I only say this because you said you couldn't hear this problem from within the cab.
Old Mar 21, 2006 | 09:35 PM
ThunderZ28's Avatar
12 Second Club
interesting Stewart...
maybe we can check it out Friday?
Old Mar 22, 2006 | 04:41 PM
Question
Didn't you have Allen change your shift points higher when we went to see him last time? I thought Allen was a bit against it if I am recalling correctly.
Or was that just 1st gear you had him raise the shift points on?
Jim
Old Mar 22, 2006 | 06:57 PM
i was holding past where we decided to let it shift. we set 2-3 at 6000 rpm but it has more in it....think im just holding it a lil too long. ill figure it out friday
Old Mar 22, 2006 | 07:12 PM
storm5.3's Avatar
13 Second Truck Club
The stock tach is a little slow so if you shifted at 6K on the tach then you probably shifted anywhere around 64-6500 or even more. When I first got my tune before I modded heavily I thought that Allen didn't set my shift right because on the stock tach it was only showing about 5600 but I was actually turning to 58 or 5900 I can't remember. Now the tach only sits at 6K for only less than a second and shifts are set at 6600 or so...Zed
