Pulleys, Efans, and stall converter
Old May 8, 2007 | 06:24 PM
trblmkr's Avatar
Default Pulleys, Efans, and stall converter
this is probably thw most rediculous question youve seen in a while but looking under the hood of my 05 rcsb 4.8 the fan looks like a efan what is the difference between stock and aftermarket?
What are your opinions on a good set of pullys to get for my truck?
And would putting in a stall converter at the same time as i put in my shift kit save any money on labor?
Old May 8, 2007 | 06:30 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
Never seen aftermarket but they probably have some type of mfg marking and the GM's don't.
ASP underdrive pulleys are the ones everyone likes.
Don't think so, to install the converter the trans has to come down.
Old May 8, 2007 | 06:32 PM
thunder550's Avatar
High on diesel fumes
What he said.
Old May 8, 2007 | 06:45 PM
trblmkr's Avatar
perfect thanks guys
Old May 8, 2007 | 06:47 PM
nightrunner's Avatar
Mr. Obvious
you should have efans stock
05 and newer trucks came with them
Old May 8, 2007 | 06:59 PM
trblmkr's Avatar
so would there be an upgrade is stock good enough
Old May 8, 2007 | 07:02 PM
LesPaul's Avatar
stock is good enough
Old May 8, 2007 | 08:55 PM
trblmkr's Avatar
Looking around for the asp underdrive pulleys cant seem to find any for 05 only the 04 and older anyone know of any websites to get them from or should i just call asp directly
LCHEE
Oct 24, 2020 04:10 PM
rednekferlife101
32
Jan 8, 2016 10:42 PM
lo&sloSierra
Jul 24, 2015 07:03 PM
ullose272
Jul 19, 2015 04:14 PM
