Pulley change
Originally Posted by wkdivr
Any installation notes, or instructions I should be aware of before changing pullies on my Radix. What kind of puller do I need?
To start off, I'm going from the stock 3.4, to a 3.2 just to see how much it gains. Just starting!
You will notice the gain!
I thought when you creeped into the 9-10 psi range you had to build the bottom end of the engine or it was on borrowed time? I am flirting with putting on a 3.2, which I already have in my garage, but am not sure if that will be pushing it.
Originally Posted by KySilverado
I'm at 3.2, I would see about 10 PSI at shifts on cold days. After the cam install it dropped to about 7PSI. I will soon be installing another.
Can't wait to get it on, then. I want to get some more track times with the current set-up first, though.
