problems getting crank pulley off
Old Nov 3, 2004 | 12:07 PM
mwalls54's Avatar
Need More N2O Mod
Default problems getting crank pulley off
its a asp under drive pulley and i have broke two harmonic balance pullers and the thing still hasn't budged, any one have any ideas or have had the same problem. i have had the thing off about 5 months ago but its not wanting to come off now.
Old Nov 3, 2004 | 12:40 PM
vanillagorilla's Avatar
Are you using a 3 prong puller? If not, then use one, you'll be wasting your time with a 2 prong. Make sure you have the bolt out too. I'm sure you do, but I gotta say it. It also helps to put in a longer bolt in the crankshaft, I think 270mm. This will prevent you from striping out the threads in the crank.
Take the longer bolt and drill into the center a little bit. Enough just to make a little cone shape. This will help locate, center and stabilize the center part of the puller. There are 3 tabs in the center of the hub, make sure the prongs are on those tabs. It takes a little bit of juggling, but have patience. Good luck!
Old Nov 3, 2004 | 12:57 PM
Flyer's Avatar
I used a Chrysler balancer pulley I 'borrowed' from AutoZone.
Old Nov 3, 2004 | 02:32 PM
ktmrider's Avatar
Flyer is exactly right, use the 3 arm puller for "Chrysler" vehicles. I am not sure about the ASP pulley but it should be very similar. If it uses the bolt in style use quality hardened fasteners and you should be good to go.
Old Nov 3, 2004 | 03:35 PM
smooth sierra's Avatar
If all else fails use a propane torch to apply some heat. then I like to use an impact on the puller to provide a little vibration. next time you put a pulley on the crank use some anti-seize. I have also seen where aftermarket pulley's had to be honed to fit the crank properly.
Old Nov 3, 2004 | 08:00 PM
What I used
Old Nov 3, 2004 | 08:07 PM
one03sierra's Avatar
Formerly one92rs
Talking
i used the same and havent had any problems.just make sure you tap the bolt holes as deep as possible and give it a shot.
Old Nov 3, 2004 | 08:28 PM
99Silver6.0's Avatar
You wouldnt happen to be using a larger version of an A/C clutch puller would ya?? Like the others have noted, get the OTC or SPX 3-arm from Oreillys or something. I had a hell of a time getting my pulley to budge. I anti-siezed the **** out of it before I put it back on.
Old Nov 3, 2004 | 09:30 PM
mwalls54's Avatar
Need More N2O Mod
thanks guys. it was siezed on there. after 2 sets of bolts and 2 pullers i finally got it off the asp udp is different from factory where the 3 finger gear puller will work, you have to use a old style harmonic balancer puller. where it has three bolts that screw into the pully and has a center bolt to press against the crank,
Old Nov 3, 2004 | 09:36 PM
v8
17,16,15,14,13,12,11 Drvr
your right lol
Tydriver
45
Oct 23, 2015 09:19 PM
kalikid06
20
Oct 13, 2015 07:37 AM
SlvrSierra4.8
Oct 1, 2015 09:39 PM
1slwgto
Oct 1, 2015 01:51 PM
Justin87gn
Sep 10, 2015 12:06 PM
