Problem for 2 months
Originally Posted by bud8fan
any reason why this is your 2nd fuel pump...or just a bad 1st pump...
Originally Posted by hotrod04
I bought the first pump from Rick at sts and later told him the problems I was having and he said he didn't think it was the pump as he had never seen a bad one, so not knowing what else to do I bought another one from neweraperformance and for some reason I got 6 wot runs that were awesome then pulled into a gas station put 10 gallons in and took off with this big smile on my face and it went back to the same **** as before???
When I would check the pump, I would think it was running when it really wasn't because it was picking up vibration from the intank pump.
Originally Posted by Black Blown 02
Are you SURE the inline pump is working? Mine worked for a while then stopped. It had a bad ground. The crossmember I mounted the pump on wasn't grounded well. I had to move the ground to the frame rail.
Originally Posted by Flyer
CHeck your rev limiters. Get an updated tune to make sure they are good.
you got 6 wot runs that were great and then it just went to **** again!!!.does'nt sound like its the pcm tho....
SWINGRRRR
Sep 3, 2015 07:49 PM
