preload?
Old Mar 13, 2006 | 03:14 PM
  #31
jus1975's Avatar
I have installed a set of Comp 918 and Pro mag rockers and stronger pushrods that are the same length as stock. But I am not sure if I adjusted the valves correctly. Is thier a correct procedure for this. I did it by adjusting the rockers according to the shop manual but not torgueing them down like the manual states. But how do you know if theirs is slop between the rods and rockers when you can't get a finger in there. And do you stop turning the adjustment screw until the rod cannot spin or just till it cannot move up and down. I saw a procedure on vinci hi performance web site. But is was for crane roller rockers. Would the procedure still be the same.
Old Mar 13, 2006 | 03:51 PM
  #32
02sierraz71_5.3's Avatar
http://www.cranecams.com/?show=faq&id=3
If I only knew then what I know now
Old Mar 13, 2006 | 04:27 PM
  #33
joshluther's Avatar
What ended up solving your power problems?
RhinoSS
Nov 30, 2022 10:31 AM
santoy956
Sep 10, 2015 03:12 PM
GM1697
Jul 20, 2015 08:41 AM
GRRR65GTO
Jul 10, 2015 08:27 PM
chris092183
Jul 22, 2011 05:34 PM
