Ported Throttle Body Problems???
Old Oct 4, 2008 | 03:44 PM
0235SS93's Avatar
Default Ported Throttle Body Problems???
I ported and half-shaft a throttle body for my 05 6.0. I was careful not to port where the blade rests. When I started the truck, it revved up to 2500-2700, fell, and idled... It does this everytime. Also, when you give it throttle, it acts like it sticks and slowly revs down. Alot slower than normal. Sometimes it idles fine, sometimes it slightly surges. Is this normal and will it go away? Or did I screw something up?
Old Oct 4, 2008 | 04:25 PM
+1 I just gave mine a tiny port job, I removed that lump on the lower part, and just polished the rest, and mine is saying Reduced Engine Power. I also marked where the blade was. I didnt cut the shaft.
Old Oct 4, 2008 | 04:52 PM
GMCtrk's Avatar
Is your DBW? The guy who did mine says he doesn't do DBW TB's anymore. Maybe porting them is a no no?
Old Oct 4, 2008 | 04:54 PM
yup
edit! When I turn the key on...and not start the truck, it displays the message too.
Old Oct 4, 2008 | 05:38 PM
0235SS93's Avatar
it's dbw. There are alot of people runnin ported dbw's. I'm not getting a reduced power message but oddly enough I am getting a oil life reset message
Old Oct 4, 2008 | 06:00 PM
cwalker2006's Avatar
i have a ported dbw tb and i have no problems with mine whatsoever..
Old Oct 4, 2008 | 06:51 PM
My problem was a minuscule amount of blade bind.
Removed the blade, and re-installed it and its perfect.
Old Oct 4, 2008 | 07:05 PM
0235SS93's Avatar
I've tried switching the blade around...no help
Old Oct 4, 2008 | 07:34 PM
your truck has to relearn its idle, mine did the same thing it'll be fine.
Old Oct 4, 2008 | 07:35 PM
viciousknid's Avatar
Where's the Beef?
Originally Posted by sharky05
your truck has to relearn its idle, mine did the samething it'll be fine.
+1 Or retune it.
By porting the TB you changed the air restriction, now the pcm is confused.
