Port and polish TB
Old Jan 22, 2005 | 08:06 PM
2000 SILVERADO's Avatar
Default Port and polish TB
Is it worth porting and polishing the TB? What kind of gains could I exspect? Thanks in advance.
Old Jan 22, 2005 | 08:18 PM
KeukaZ71's Avatar
i never done this mod, but i think you will just notice more throttle response. i don't think you get any RWHP from it
Old Jan 22, 2005 | 08:46 PM
GEAR M UP's Avatar
I dont know what kind of gains you'll get from it....But I have done it on every stock TB I've had.....
Just dont go to deep..
Old Jan 22, 2005 | 08:50 PM
Porting the stock throttlebody can give a increase in performance usually at the expense of throttle response and drivability.Don't even consider it with a drive by wire setup.
Old Jan 22, 2005 | 09:00 PM
I woundnt expect any gain from it. I havent done it nor will I do it.
BTW, over the past year I have learned some stuff with free mods, usually no noticable gains and usually you have to replace the part you worked on. Dont descreen the MAF, and if you never ported a TB dont touch it let some that had done it before do it. Just save the cash and get a exhaust and a Nelson tune and a KN filter.
Old Jan 22, 2005 | 09:07 PM
When I had my Silverado, I bought a P&P TB, didn't notice much from it and I also got an intermitent SES light after I installed it that never came back after I took it off. I took my stock TB and smoothed it out, it had rough edges on it and the TB surface was rough. I took some very fine sand paper and just smoothed everything out, not really a P&P, just got everything smooth. Seemed to work better than the P&P TB I bought, so I kept it and sold the other one.
Jim
Old Jan 22, 2005 | 09:38 PM
I was thinking about doing that and the port and polish, but it doesn't seem worth it now.
Old Jan 22, 2005 | 09:43 PM
BlownChevy's Avatar
blownerator
25 Year Member
Spend your time waxing the truck. It will give you the same gains.
Old Jan 22, 2005 | 11:57 PM
greentahoe's Avatar
Ive noticed that every high hp cam only setup has had a ported and polished TB. This may be coincidence, but since I had to take mine off to clean it I figured I might as well clean it up. I simply smoothed the lip and did some minor porting on the inside to smooth everything out and got rid of that huge ridge that is a bit before the blade. Im going to polish it tomorrow. It really wasnt hard at all and I had fun doing it. It cant hurt as long as you dont port around the blade and with a blower I figured that making a less turbulent path and smoothing out the air flow cant hurt.
Old Jan 23, 2005 | 03:11 AM
chris99gmc's Avatar
I couldn't imagine how much time you'd waste doing this worthless mod.. if you ever log your truck before and after and notice some gains, let me know cuz I'd be rather amazed.....but afterall, you wouldn't loose anything unless you drilled though the side, so go for it if you're actually THAT bored.
