please help what comes with a lq4
Old Feb 23, 2010 | 01:21 AM
s10pro's Avatar
Default please help what comes with a lq4
looking to do a lq4 swap with a 4l80 in my 92 gmc typhoon need to give salvage vard a vech or vin to find this lq4 in also what truck to get 4l80 from. Thanks for all your help
Old Feb 23, 2010 | 01:37 AM
Parke10's Avatar
a little search will go a long way with this..but just as a little help 1999+ 2500/3500 Trucks and Vans. i think there is others too.
Old Feb 23, 2010 | 08:57 AM
thunder550's Avatar
High on diesel fumes
VIN, 8th character, look for U
Old Feb 23, 2010 | 11:09 PM
s10pro's Avatar
i was told all gmc denali's have lq4 is this true
Old Feb 23, 2010 | 11:22 PM
Mangled03gmc's Avatar
Baltimore Whore
The way to tell the 6.0 motors, they will have aluminum heads, the numbers on them is 317, besides the 99-late 01, which are steel head motors... Yes denalis have the lq4 in them.. Why do you want a 4l80 in such a light truck??? A built 60 will be more then enough, unless you plan to make a *** load of hp
Old Feb 24, 2010 | 08:48 AM
1Bear's Avatar
In general, the Denali’s ’01 thru the ’07 Classic’s had LQ4’s except the ’05 + Sierra Denali’s that came equipped with the LQ9. Stay away from the ’99/’00 models, as they had the iron heads and long crank. The crank is not that big of an issue as long as you are sure that you are going to use a 4L80, but if you’re not sure, just stay with a newer model. As stated, when looking for a LQ4, just look for “U” in the vin number. If you were to get lucky and find a vehicle with “N” in the vin, you would have a LQ9 on your hands as long as the vehicle has not been molested. But as was also already stated, if you want a LQ4/4L80 combo, it would be the easiest to just look for a 2500/3500 equipped truck and get all of your parts at once, it could save you some headache in chasing small components and insure parts compatibility.
Old Feb 25, 2010 | 01:17 AM
s10pro's Avatar
thanks for your help, one other ? tranny guy said to look for 4l80 with bolt in bellhousing at 12:00 do all 2001 up 4l80 have this
calsdad
Jun 14, 2023 11:07 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
lxcoupe
Sep 29, 2015 09:20 PM
Slammed silverado
Sep 28, 2015 06:14 PM
zraffz
Sep 8, 2015 07:40 PM
