Please help with supercharger
Old Apr 20, 2004 | 04:50 PM
Yellowsierra's Avatar
Default Please help with supercharger
i have the 4.8 with the whipple supercharger and was wanting to reach 10 ibs of boost.My pulley size is 4 5/8 and with this pulley i am making 5 1/2 pounds of boost.i need to know what size pulley to get 4 1/8 ,4 , or 3 7/8 please help.
Old Apr 20, 2004 | 07:04 PM
454SuperSport's Avatar
every 1/8" is about one pound. a 4 1/8" pulley would be 9-10 pounds of boost. just a warning though, i have a 9 lb. pulley that i use at the track but i have to run 100 octane race gas or it will spark knock pretty bad. i'm pretty sure 6-7 lbs. is the limit for pump gas
Old Apr 20, 2004 | 08:55 PM
01Sierra's Avatar
Well I dunno if there is a difference btw a twin screw and a roots as far as boost limits but I know my buddy has a Lightning and that thing makes 9-10 lbs easy on 93 octane... might be more but not sure...
Also on another note... what kinda track times you puttin down 454?? I gotta RCSB 5.3 3.73's and I wanna throw on a Whipple...
Old Apr 20, 2004 | 08:59 PM
8ALTNG's Avatar
Yellow- I am running a 4.8 w/ a magna charger and am gettin 10lbs with a 3.25'' pulley. You just want to watch that you dont start lifting heads with running to much boost. It suxs. trust me
Old Apr 20, 2004 | 09:01 PM
Ryan23silverado's Avatar
Yup
Old Apr 20, 2004 | 10:41 PM
the lightnings and the radix kits can put out more boost on pump gas cause there intercooled. and 01Sierra, it went 13.3@102 a few weeks ago.
Old Apr 21, 2004 | 05:42 AM
02Reaper's Avatar
The lightning does this with an intercooler and a lower compression ratio. the high compression ratio on the 4.8, 5.3, and lq9 limit the amount of boost you can run on pump gas without detonation.
Old Apr 21, 2004 | 11:38 AM
2ksleeper's Avatar
You have to be alittle carefull when you get advise about different boost pressures for a given pulley diameter because the following can affect pulley size on your whipple:
- (1) belt set-up or (2) belt set-up
- engine displacement
- crank pulley size for (2) belt set-up
But a good rull of thumb is for every .125" smaller pulley = ~1 psi boost.
Old Apr 21, 2004 | 10:19 PM
The way I was going to run more boost(10 pounds) was with the aquamist water injection. It allows you to run 3 to 4 more pounds of boost by cooling the air in the engine. I hope it works out.
Old Apr 22, 2004 | 06:06 AM
2ksleeper's Avatar
I plan on doing the same but with smc akli injection kit & methonal & from my guesstimat for 3+psi boost & the injection kit should =~50hp more to the wheels.
moregrip
Jul 26, 2016 11:21 AM
5speedsilverado
Sep 25, 2015 06:50 PM
bagged7104SS
Sep 24, 2015 08:42 PM
2004gibbstruck
Sep 7, 2015 06:05 PM
