Please help with supercharger
i have the 4.8 with the whipple supercharger and was wanting to reach 10 ibs of boost.My pulley size is 4 5/8 and with this pulley i am making 5 1/2 pounds of boost.i need to know what size pulley to get 4 1/8 ,4 , or 3 7/8 please help.
every 1/8" is about one pound. a 4 1/8" pulley would be 9-10 pounds of boost. just a warning though, i have a 9 lb. pulley that i use at the track but i have to run 100 octane race gas or it will spark knock pretty bad. i'm pretty sure 6-7 lbs. is the limit for pump gas
Also on another note... what kinda track times you puttin down 454?? I gotta RCSB 5.3 3.73's and I wanna throw on a Whipple...
Yellow- I am running a 4.8 w/ a magna charger and am gettin 10lbs with a 3.25'' pulley. You just want to watch that you dont start lifting heads with running to much boost. It suxs. trust me
Originally Posted by 01Sierra
Well I dunno if there is a difference btw a twin screw and a roots as far as boost limits but I know my buddy has a Lightning and that thing makes 9-10 lbs easy on 93 octane... might be more but not sure...
You have to be alittle carefull when you get advise about different boost pressures for a given pulley diameter because the following can affect pulley size on your whipple:
- (1) belt set-up or (2) belt set-up
- engine displacement
- crank pulley size for (2) belt set-up
But a good rull of thumb is for every .125" smaller pulley = ~1 psi boost.
The way I was going to run more boost(10 pounds) was with the aquamist water injection. It allows you to run 3 to 4 more pounds of boost by cooling the air in the engine. I hope it works out.
