piston ring question
Old Feb 3, 2010 | 01:33 AM
bohr898's Avatar
Restricted User
Default piston ring question
i recently had a 1k mile lq4 engine put in to my truck... it only has 10k on it now and got a set of lq9 flat top pistons just sitting in the garage... they dont have rings on them and was wondering if i could take the rings off the dished lq4 pistons and put them on the flat top lq9 pistons because they are both 4 inch pistons.... could this work??... i would make sure to keep the rings in the same cylinder bore also... engine makes great compression and doesnt smoke........everything is arp studded so dismantle/rebuild expense is not an issue
Old Feb 3, 2010 | 09:58 AM
cmiller's Avatar
ive always been told never reuse rings.
Old Feb 3, 2010 | 07:54 PM
bohr898's Avatar
Restricted User
rings soo expensiveee to me
Old Feb 3, 2010 | 09:24 PM
Pontiac Derek's Avatar
Yes you can, just make sure every thing is the same on the lq4 pistons and put the rings in the same bore they came from
Also for taking them apart and reinstalling the rings use a ring spreader dont twist the rings on, that tool is 8$
Also make sure you won't be having any piston to head or piston to valve issues
Good luck it should be fairly straight forward
cmiller's Avatar
150 bucks?
Old Feb 5, 2010 | 02:24 PM
bohr898's Avatar
Restricted User
thanks for the help PD.. and yes i got one of those ring tools
Old Feb 5, 2010 | 05:51 PM
454navyss's Avatar
rings are too cheap to risk screwing up an engine, hone the cylinder walls and put some new rings in it
Old Feb 5, 2010 | 06:42 PM
gmcboy2002's Avatar
ya i would just replace the rings if u r already going to have the pistons out!
Old Feb 5, 2010 | 10:22 PM
bohr898's Avatar
Restricted User
depending on the looks of the cylinder walls will be the deciding factor i guess... thanks for all your help everyone
ferrellrooster
Mar 6, 2025 03:22 PM
5.3lSilverado
25
Aug 29, 2016 12:48 AM
JordanH
Aug 8, 2015 07:59 PM
USMCvet0311
Aug 1, 2015 07:45 AM
1320Chicken
Jul 14, 2015 10:58 PM
