Picked up an LQ9! Need some help
Old Sep 14, 2009 | 02:47 AM
charlie_riggs's Avatar
go with the melling high pressure oil pump they are about 130 on summit, i have heard that the ls2 is a double roll timing chain and if you dont change the timing chain cover to the ls2 one it will leak so just do reseach on it before you buy one. i have reused my ft and rear cover gaskets muti times and never had a leak just make sure that you dab some rtv on the oil pan were the cover meet the it. try to buy the tri-metal header gaskets you can reuse them. go the ls1 how to and get the torque specs, i had stripped some by over torquing with a 1/4 drive so be careful
Old Sep 14, 2009 | 02:51 AM
on camp cams web site is a form that you can fill out and they will reply back with what what they think will be best and call texas speed and ask them too
Old Sep 15, 2009 | 08:00 PM
jhe2003's Avatar
Just a quick update!
This showed up during the week!
220/220 581 581 116 LSA
Springs, retainers, pushrods
Items to come
Arp Bolts
Ported LS6 pump
Cam install kit(gaskets, bolts, seals)
TB stall
As you can see its a very mild setup but it should be fun to drive and a stockish idle!
Old Sep 18, 2009 | 10:53 AM
FastKat's Avatar
What other trucks had the vette style DBW, and what years? Did any other 6.0 4L80E trucks have the vette style DBW?
Originally Posted by GMCtrk
that's incorrect. The 02 LQ9 had the vette style DBW TB
natejk
Nov 15, 2016 08:05 AM
mitchellmade
Sep 27, 2015 08:25 PM
CammedZ71
11
Sep 9, 2015 02:05 PM
zraffz
Sep 8, 2015 07:40 PM
