Performance on a SBRC 5.7...
Old Apr 29, 2005 | 03:25 PM
b0b's Avatar
b0b
Question Performance on a SBRC 5.7...
Hi guys, Im new here, and was told this is the best GM forum on the web, and after some reading, I believe it. I have an older truck, a '97. Its a SBRC c1500 w/a 350. I am seriously going about finding some boost. I am trying to keep away from a turbo, and going for a Magna. My main question is, will a charger work well in conjunction with a 100wet-shot?? My motor is older, yes, but it has very low miles (26k), and am not too worried about running 100shot, as that seems pretty safe. I will also be adding headers, cut-outs, high flow cats, 180 stat, shift kit, alum heads, and a cam. I need some help with the cam part of it though. I have no clue what I should go with. I want the max power out of it, and a little lope. I am assuming there is a type that is better suited for superchargers, so I need major guidence there. I dont want to have huge 3in true duals, or a full-blown straight-pipe (except for the cuts of course) as that seems a little excessive. There is a thing as too much exhaust I believe, and I want to holld on to what little bit of fuel economy I'll have left after all this. Any suggestions on header/cat/cut-out/muffler combos will also be greatly appreciated. My final question is just how much hp can the stock 4l60e (M30) hold???? I am going to be adding some serious power here, and want to know how hard I am going to be pushing the tranny..... The Nitrous I plan on using is a 100wetshot universal fogger from NOS. I want to use a window switch from around 2800-5500. Any suggestions, tips, pointers, etc are GREATLY appreciated. I am somewhat new to this, but I have read alot, and asked around on a few other mb's, and still dont have much for answers. I know its a lot of ?'s, but I really need to know. thanks in advance.
Old Apr 29, 2005 | 04:13 PM
litreddevil's Avatar
Banned
call Ed Wright @1-918-446-3019 he is the best person for a R motor
Old Apr 29, 2005 | 04:35 PM
CAMMIN03''s Avatar
Banned
I dont know much about Boost and Nitrous... but
Im going to go safely with my guess and say I wouldnt shoot a 100 shot with a supercharger.... Im not sure that a stock bottom end could hold that....
I could definently be wrong.... I would go Magna and a 35 shot or 50 shot
Good luck... Welcome to the site
Old Apr 29, 2005 | 06:07 PM
You say you want a little lope. Usually blowers ( I'm no expert) don't like lope. Allows boost to escape through the exhaust during the "lope".
Old Apr 29, 2005 | 10:16 PM
b0b's Avatar
b0b
I think maybe 35-75 is more like it. A stock bottom with 100... I dont know, if anyone else can verify any of this, it would be great. Also, if lope lets boost escape, what kind of cam will give performance+holp as much boost in as possible?? Thanks
Old Apr 30, 2005 | 10:21 AM
b0b's Avatar
b0b
up...
Old Apr 30, 2005 | 03:08 PM
Mangled03gmc's Avatar
Baltimore Whore
I think you would be fine with a 100 shot on a n/a motor but with a charger or turbo you could probably tone it down some.Nitrous seems to make more than what you spray on a F.I motor.
Old May 1, 2005 | 09:29 AM
b0b's Avatar
b0b
do you have a cam suggestion...
Old May 1, 2005 | 06:57 PM
Something with a 114 or higher lsa. Better idle quality and not much boost robbing lope.
mikeyjm1
17
Oct 29, 2015 11:04 PM
gaps
Oct 15, 2015 02:53 PM
gavin2005
Sep 13, 2015 09:04 PM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
montecarloss
Sep 2, 2015 04:44 PM
