PCV system with oil separator
Old Aug 19, 2016 | 10:34 PM
Only the NNBS trucks run that hose to the intake tube.
Old Aug 20, 2016 | 09:56 AM
Dan Neumann's Avatar
Originally Posted by 2xLS1
How hard headed are you. The TB port IS in front of the throttle blade and is a fresh air source for the pass side valve cover port. It provides filtered air to the crankcase to replace dirty air pulled out of the drivers side valve cover.
That maybe so as I haven't made it a mission to remove and inspect the details of the TB completely. Apparently that tube from the TB to the VC isn't ideal because I've seen many threads on forums where it's recommended to remove it, cap the ports and put a breather where the oil fill cap is. Some crankcase vacuum is actually good. It improves ring seal so I'm good with the current configuration right now.
Furdkiller
11
Nov 8, 2018 09:04 AM
02Sierra2500hd
Mar 23, 2016 10:30 AM
OHsixLS3
Mar 6, 2016 09:35 PM
JUSTINB
Apr 24, 2002 01:23 AM
